Battery - Major Cell deviations - Charger?
Discussion in 'Pro/Adv Discussion' started by Danderse, Oct 5, 2015.
  1. Danderse
    Hi Guys;
    I am just wondering...of us that are showing major deviations on Healthydrones...
    Are you seeing major deviations in excess of 4-5 per flight?
    Which Charger do you have PRO (100W)?
    Or Advanced (57W)?
    Wondering if the deviations might be related to the charger used.
  2. N017RW
    Palm Beach Co.- FL
    The chargers are just power supplies.
    The balancing and other protections are part of the 'intelligent' hardware stuck to the top of the battery that DJI charges about their weight in Gold for.
  3. Danderse
    Thank you, I understand that...however to charge a battery in half the time,this means that the charge variables applied to the battery is different from one to the next.
    The intelligent charger (within the battery case) is definitely executing a different charge routine and charge variables to shorten the charge time.
    That being said...Yes, I stand corrected, thank you, it is the battery charger once connected to the 57W or 100W power supply that is responsible for the difference.
    Really, it comes down to this...
    Are PRO owners seeing more deviations than Advanced owners.
  4. N017RW
    Palm Beach Co.- FL
    I have argued for a while (by only monitoring the voltage during charging) that the charging profile used does not appear to be the typical CC/CV provided by typical LiPo chargers.
  5. tcope
    Salt Lake City, UT
    Charging time is diminished only because the wattage is increased. That is, the rate that the same energy is pushed. It's still balanced the exact same way. It's like having a bigger pipe to carry water but it's still divided in half.
  6. Nstrong48
    Milan, MI
    more water leaves more room for error though.
  7. N017RW
    Palm Beach Co.- FL
    Can you explain?
  8. Nstrong48
    Milan, MI
  9. N017RW
    Palm Beach Co.- FL
    :confused:
  10. tcope
    Salt Lake City, UT
    May want to look up the word, analogy.
  11. Nstrong48
    Milan, MI
    lol, neh
  12. Danderse
    So again...the fact is charging is faster with more charge current for the PRO....so....
    Do the PRO users see more cell deviations, once charged and put under load (flown).?
Similar Threads - Battery Major Cell Forum Date
Powerextra (off-brand) battery - major cell deviations Pro/Adv Discussion Nov 28, 2016
Battery cell major deviations Pro/Adv Discussion May 12, 2016
P3P Battery Major Deviations Pro/Adv Discussion Feb 8, 2017
Battery - "Major Deviations" reported Pro/Adv Discussion Dec 19, 2016
Compass Error, Battery Fault, Major Lag - Time for an Upgrade Pro/Adv Discussion Oct 10, 2016
