No, CSC's don't cause an RTH (Return To Home), they cause an RTG (Return To Ground).
Sorry my bad, I thought the bird dropped from the sky.
That's an easy mistake to make. Here's the OP's original comment:Sorry my bad, I thought the bird dropped from the sky.
Oh, I just couldn't resist. Second expresso of the day and all that.Sorry my bad, I thought the bird dropped from the sky.
How old is this battery? Do you store your batteries fully charged? If so when was the last time you used this battery? If you are not flying within a week of fully charging them they need to be discharge back down to about 40% if not planning to fly anytime soon. I had the exact same thing happen using a battery I left fully charged all winter. The battery was swollen and gave a false charge reading and within 3-4 minutes of flying it went from 96% to 50% then 20% then auto land and I could not get it to return.Help.
Drone was about 100ft in the air and i was about to land when i heard message "battery level is low - the aircraft will head to homepoint in 20 seconds". My screen was reading about 50% battery level.
At this pont i was far away from the homepoint.
I tried to land the drone but it kept going away from me and it headed straight into trees. It crashed into a tree and heavy brush...
This happened about 45min ago and I was able to recover it. I havent powered it at this point and will be contacting DJI.
Is this usually covered under warranty?
