Advanced Battery firmware upgraded one but not the other?
Discussion in 'Phantom 3 Help' started by Gnasher, Aug 21, 2016.
  1. Gnasher
    Ive carried out the latest firmware upgrade. I had an error message saying the upgrade failed but it wouldn't accept a 2nd attempt and when I checked the version it appears the upgrade did indeed upgrade.
    When I put the 2nd battery in to accept the upgrade it doesn't take it? So I have one upgraded battery and one not?
    Any ideas?
    Thanks - Jon
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's possible that your battery does not need to be updated. DJI GO will display a message if you're using a battery that needs to be updated.
    ROD PAINTER likes this.
  3. Gnasher
    I get a firmware required message on one battery and not the other.
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It sounds like you only have one more battery to go then. Go ahead and install the firmware on that battery.
  5. Gnasher
    Thats the problem.See my original post Its not accepting the update.
  6. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Which BIN is on the memory card?
  7. Gnasher
    P3S_FW_V01.09.0060.bin.cpgz - It upgraded the drone despite it giving me a fail message and also upgraded one battery but refuses to upgrade the 2nd.
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That might be your problem. The filename should end in ".BIN".
  9. Gnasher
    Dohhh - That fixed its and now i feel suitably stupid - Thanks for that. Im desperately trying to get things up to spec for my commercial flight test this week but the P3 is acting up. Keeps loosing its image feed and the delay between capture and seeing the image on screen is upto 5 secs. Do you or any one else happen to know if this is normal? I
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    What kind of mobile device are you using? Do those things happen the entire time or only after you've been flying for a while?
  11. Gnasher
    Iv'e only just noticed it happening. I have an Iphone 6s and iPad mini as well as a iPad pro . The lag happens on on of the devices. Im playing with settings as I write this and iv'e just turned off the video cache and thats made a very noticeable difference.
  12. msinger
    Approved Vendor
    Harrisburg, PA (US)
Similar Threads - Battery firmware upgraded Forum Date
Help - I upgraded firmware & calibrated, now battery issues Firmware Jan 12, 2014
New Battery firmware upgrade question Pro/Adv Discussion Jun 30, 2017
P3 Firmware Battery / AC firmware mismatch Firmware May 12, 2017
Remaining Battery Time Algorithm Changed in Latest P4P Firmware Update? Phantom 4 Pro Help Apr 1, 2017
P2 Firmware Downgrade firmware for non-OEM battery Firmware Mar 28, 2017
