Battery firmware upgrade
Discussion in 'Pro/Adv Discussion' started by kphantom, Dec 26, 2015.
  1. kphantom
    I have 3 batteries. If I upgrade firmware to 1.6 do I just install each battery as I fly and the battery will upgrade?
  2. Donw35
    Los Angeles
    leave the firmware file on the SD card, put in the next batter and turn on the P3, it will upgrade the battery, do that for all three. Done..
  3. TrynFlyn
    If you leave the .bin file on the SD card, yes you can do it that way. It will take a few minutes to update the battery before your ready to fly though.
    Better to do it at home, one battery after another. Then you can delete the .bin file from the card.
  4. kphantom
    Awesome, thanks. Is there someplace to see the revision of installed battery firmware?
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    No.
  6. kphantom
    That would be a good feature to add to the Go App in the battery settings and detailed status section.
  7. Donw35
    Los Angeles
    You can see the version, the hidden folder on the SD card will have P3X_FW_LOG_AB.txt file, in that you will see the version of the battery FW.
    Before
    [00013722][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
    After
    [00075148][11 00][05] v1.7.15.1 -> v1.7.15.1
  8. TrynFlyn
    Wouldn't it show in the log file? [11 00]
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yes. But, you cannot see the currently installed firmware version anywhere -- like in the About section of the DJI GO app.
Similar Threads - Battery firmware upgrade Forum Date
New Battery firmware upgrade question Pro/Adv Discussion Jun 30, 2017
Professional Battery firmware upgrade Phantom 3 Help Nov 26, 2016
New Firmware Update/upgrade, possible battery confusion? Phantom 4 Help Oct 14, 2016
Battery Firmware Upgrade Pro/Adv Discussion Oct 12, 2016
Help needed with P2V+ battery firmware upgrade Phantom 2 Vision Help Sep 28, 2016
