Anyone else have an issue with this door? I'm just using electrical tape to insure it stays closed but I hate literally band-aiding a problem.
750r said:After a lot of reading on this site and other sites I have seen this problem a few times . The quick fix was to take a match and heat up the tab on the door and bend it up just a little and hold it till it cools down . It should fix your problem . I had a different problem my 3rd party batteries had a lot of wire and was real hard to get it all stuffed in so I got a bigger door 18mm all is good now .
750r said:They make a door with slots cut out for you to . This is the door I got went with red being it's the front of the bird.
http://www.shapeways.com/model/1110056/big-battery-door-upgrade.html?li=productBox-search
They make a 12mm you could probably get by with it I've read other people just having just enough room I wanted to make sure I had plenty of room .
