Battery Discharge Method
Discussion in 'Pro/Adv Discussion' started by 0000edgar0000, Dec 11, 2015.
  1. 0000edgar0000
    How often should i completely discharge the batteries? What's the best method to discharge them?
    I have two batteries and will usually swap batteries as soon as i get the low battery alarm. I believe threshold is set around 35%.
  2. MrMcfly
    Melbourne, FL
    It is my understanding that you should run your batteries down to 8% every 20 charges. I've not reached 20 yet,
    but I have discharged my batteries for "shelf time" . Down to 65%... I simply did this by flying. If weather didn't
    allow, I would just run the motors at idle till the level drops to 65%. This can also discharge the controller, which
    seems to drain a bit slower.
    I've been flying my batteries down to 50% for the 1st several flights, as recommended on this forum. Letting the
    batteries rest before plugging them in to charge again.... but this is how I do it.... I'm sure there's others that will chime in.
    The batteries are set to start 'auto' discharging after 3 days.
  3. RedHotPoker
    Edmonton Alberta
    If you are using an iOS device, well any device actually now, don't forget to utilize your flight SIM, to drain down drone and radio battery voltage. I wish we could plug the radio into a large monitor for the SIM. ;-) like www.realflight.com uses.
    RedHotPoker
  4. UpTo90
    Hamilton, Ontario
    If you're an iOS user with an Apple TV you could use AirPlay mirroring while using the simulator. I hadn't thought about doing this until I saw your post... now I'm excited to give it a go!
  5. RedHotPoker
    Edmonton Alberta
    That's an awesome idea. Let us know how it works. Thanks.
    RedHotPoker
  6. UpTo90
    Hamilton, Ontario
    I just tried it out and it works great!
    It does feel like there's an added bit of latency but it's definitely tolerable for SIM use. If I end up having to work with the SIM for the lions share of the winter, it's nice to know that I'm not stuck staring at a tablet.
    *Added bonus: by the time spring weather rolls around it'll be a pleasure to once again feel how responsive the actual P3 is!
  7. RedHotPoker
    Edmonton Alberta
    Thanks for the info. Happy that I mentioned this.
    Something else to invest in. Awesome. ;-)
    RedHotPoker
  8. ScopeTech
    And you should be able to cast an Android to a Chromecast or Roku stick while flying the sim.
  9. RedHotPoker
    Edmonton Alberta
    You should possibly look into purchasing www.realflight.com. ;-)
    They have an all drone version now.
    The technology available today, pretty astounding eh? Hehe
    RedHotPoker
Similar Threads - Battery Discharge Method Forum Date
Advanced Battery discharge methods Phantom 3 Help Dec 14, 2015
Battery overheating discharge? Pro/Adv Discussion Aug 15, 2017
Battery self-discharge and timeline until death. General Discussion Aug 14, 2017
LAG problems on battery almost discharged Phantom 4 Pro Help Jun 1, 2017
Standard Can Battery Auto-Discharge Take Place During Flight? Phantom 3 Help May 12, 2017
