Battery compatibility
Discussion in 'Pro/Adv Discussion' started by phantomgaz5, Mar 20, 2016.
  1. phantomgaz5
    Hi all just wanna no can I use p3p batteries in a standard? And vicky verka . Are the batteries the same all models? Thx
    #1 phantomgaz5, Mar 20, 2016
  2. With The Birds
    Australia
    P3 batt is same for all variants. Not sure if the firmware on the batt differs between models though. DjI go should tell you when you power up if it does.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The battery firmware is identical. I routinely swap the same Phantom 3 batteries between my P3P, P3A, P3S, and P34K.
  4. phantomgaz5
    Fantastic! Thanks for your help!!
  5. alokbhargava
    San Francisco, CA
    You can easily switch batteries between different P3 variants. All should be OK.
Similar Threads - Battery compatibility Forum Date
Battery & charger compatibility Phantom 4 Pro Help Apr 1, 2017
Phantom 4 Pro Battery Compatibility Phantom 4 Pro Discussion Nov 16, 2016
P4 battery compatibility Phantom 4 Discussion Mar 20, 2016
Battery compatibility between V2 and V3 General Discussion Mar 13, 2016
EOS Battery Checker Compatibility Phantom 1 Help Aug 12, 2013
