Ive continued to fight with my h3-3d intermittently drifting left and then snapping back to center.
Today I decided to look at the mounting of the gimbal more closely and see if there was any thing that might be "off".
Started off inspecting with the battery out and there was no obstructions to the movement of the gimbal at all.
Put the battery in, tried again and immediately noticed that the yaw axis was much tighter. Pulled the battery out.. Smooth as silk again. Put the battery back in slowly and sure enough the gimbal starts moving as the battery rubs past it and once its seated the yaw axis remains much tighter than with the battery out.
I'm using the white rubber dampers. Tried to remount with some small washers in between the mount plate and the phantom body but the screws are just a wee bit short. Hopefully I can find some at the hardware store tomorrow that will work.
Could this be part of my problem?? I could certainly see the computer trying to over compensate for the constant friction that the battery is causing??
Thanks in advance
Thanks in advance
