Battery Chargers
Discussion in 'Other DJI Multi-Rotors' started by ladykate, Mar 24, 2014.
  1. ladykate
    Bellevue, NE
    Thinking about building a bigger system (just thinking right now). Looking for a reasonable battery charger. In another thread, the B6AC was mentioned. Will it charge 6S batteries? Looking at the pictures, it seems I would need to somehow connect the main leads and I'm not sure (since I don't have it in front of me) if I'm seeing that right.
    Edit: Found the answer to 6s in another advertisement (yes). Still would like to know any feedback. Thanks!
    In addition, the ROBBE was mentioned.
    Any others and, if you have one of the above, what is your experience?
  2. OI Photography
    Clarksville, TN
    The B6AC can indeed charge up to 6S, even my Turnigy Accucel-6 can do that (along with most chargers in that class). However, the limitation is the number of amps they'll put out...the B6AC is capped at 5A, which would be the standard 1C charge rate on a 5000mAh battery...so if you want to charge them any faster than that (or charge larger or multiples at once), you'll need to get one with higher output, and that'll start putting you in the $100+ range.
    As you noticed the B6AC doesn't come with an XT60 adaptor, but it's easy to make one (just spice the connector on one if their wires in place of whatever connector you don't need). Some chargers in that class (like the Accucel-6) do come with an XT60 adaptor, it just depends on the exact model you get.
  3. labmansid
    Texas, USA
    I just ordered an iCharger 306B last night. I had been looking at the 206B, but decided to upgrade for just a few dollars more for a little futureproofing and capacity. I was thinking about some more remote locations I might be going to in the future, and wanted the option of being able to recharge in the field if necessary, and not have to wait a couple of hours for batteries to recharge or lug several pounds of batteries with me. I didn't go for the full 1000W power supply it is capable of handling, just a 500W one for now. Will report back later, if I don't blow myself up! :mrgreen:
    Mike Mauk likes this.
  4. OI Photography
    Clarksville, TN
    What power supply did you get?
  5. FangsCPO
    Chula Vista, CA
    What's the highest amps you can charge with this charger?
    Sent from my SCH-I535 using Tapatalk
  6. labmansid
    Texas, USA
  7. ladykate
    Bellevue, NE
    I thought I had an iMAX B6 on order but the order was apparently not processed. So I ordered one of these. I was figuring what the time would be to charge some new high capacity batteries I'm getting and realized it would take the better part of the day to get a 20% battery charged with the B6.
  8. labmansid
    Texas, USA
    So what kind of batteries are you looking at?
  9. ladykate
    Bellevue, NE
    10 amp 6s. They are sitting on my bench waiting for a charger with a 6s balance port.
  10. labmansid
    Texas, USA
    OK then! Those should push some air. I got my charger yesterday, but have to work the next few days including yesterday and today. :cry:
  11. ladykate
    Bellevue, NE
    Didn't get the 306B - got the 208B (500 watt version) - came in today and I took it out, soldered some plugs on the batteries and charged them less than an hour. Very cool (actually, literally - the batteries didn't warm up much at all). Also got one of the modular charge boards so I can do two at once.
    Will update the bigger hex thread elsewhere but I finally got all the parts (less one which is coming tomorrow but isn't needed for a while).
Similar Threads - Battery Chargers Forum Date
Phantom 2 battery chargers Classifieds Jan 31, 2017
DJI Phantom 3 battery and chargers. And props Classifieds Jan 16, 2017
Yay or nay on off-brand multiple battery chargers? Phantom 4 Pro Discussion Jan 8, 2017
(SOLD) Phantom 3 battery chargers - Brand New Classifieds Jul 14, 2016
Phantom 2 battery and chargers Classifieds Jun 1, 2016
