  1. Carlpembroke
    Had my reasonably new battery come up on screen as cell damage or failure or words to that effect so flew it back landed and took vattery out, switched it off and on and warning had gone. Is this a common problem ? The battery has hardly been used.
  2. John Locke
    Yorba Linda, CA
    I've never seen that before. You should look at the flight log to see what it says. Do the battery cell deviations look ok?
  3. Michaelangelo
    This happened to me. In my case, I attempted to turn off my battery after a flight. Unknowingly, I didn't. The phantom was loaded back into the case and not checked on for several hours. I retrieved the case from my trunk hours later to find an extremely hot case, phantom and battery. I believe it would've caught fire had I not checked on it. Anyway, checking the history on the battery it showed that the battery got too hot and a damaged cell. You might want to check the history on that battery to see what happened. My case was totally my fault. You, however may have a bad battery. I use that battery only for per flight, on the ground checks. It's handy for that and that's all. Good luck with your situation.
Similar Threads - Battery cell damage Forum Date
Battery cells damaged Phantom 4 Pro Discussion Apr 3, 2017
battery cell damaged error Phantom 4 Discussion Jan 10, 2017
Recycling damaged battery cell Phantom 4 Discussion Aug 30, 2016
Battery error, cell damaged Pro/Adv Discussion Jun 11, 2016
Advanced Damaged cell on battery Phantom 3 Help Feb 18, 2016
