Battery and Super charger Q
What batteries do you use for your phantom?
What Super charger (brand and model) would you recommend for faster recharging?
3 cell lipo's with 2200mAhr capacity matches what DJI supplied with the Phantom. I switched over to Dean's connectors to match my other stuff (heli's).
I use an Astroflight lipo charger. It takes a seperate power supply for AC charging though. It does a great job but it's not the most economical choice.
You don't want to charge your batteries any faster than 3A.
..most people recommend 2A or even 1A if you want to make your batteries last a bit longer.
I want to have the option of using super charger, not always but when I am shooting video on a site and use up my 4 batteries.
The charging current depends on the capacity, and a lot of the newer LiPo's can be charged at 2C or even 3C. With a 2200 mAh pack that means you can safely use 4 amps. Just check the LiPo's data sheet for the max charging rate. For the first few times of use a lower charging rate is recommended tho.
A good read on LiPo's: http://www.rchelicopterfun.com/rc-lipo-batteries.html
On chargers: http://www.rchelicopterfun.com/rc-battery-chargers.html
cgarner1
