battery and charger
Discussion in 'General Discussion' started by bcass1, Aug 25, 2014.
  1. bcass1
    Can some one tell me if it is better to keep the battery attached to the charger after charging or is it better to disconnect the battery. Sometimes it's a few day between flights and I want my batteries at full capacity. Does the charger go into trickle charge and keep the battery topped off?
  2. N017RW
    Palm Beach Co.- FL
    Unplug. It shuts off anyway.
    i.e. It does not trickle charge.
    If possible store lipos at about 2green LED bars between flights.
    This will help extend life.
    You can Google LiPo care for more info.
  3. HarryT
    Warrington, UK
    You absolutely MUST disconnect the battery when it's fully charged: this is essential.
    You shouldn't store LiPo batteries fully charged: if you're not going to use a battery for a few days, charge it to 50-70% capacity (2-3 illuminated bars) and store it in that state. Top it up (it'll only take a few minutes) before you fly.
  4. bcass1
    Thanks for the info. Any suggestions on how to discharge the batteries to recycle them. Run the copter with no props until the battery is drained?
  5. HarryT
    Warrington, UK
    Hovering the Phantom until the battery falls to the desired level is the fastest way.
  6. ProfessorStein
    Portland, OR
    I think he means to the 8% that DJI recommends for a deep cycle, Harry. I would hope you don't do that while hovering... even if the firmware let you. ;)
    But, yes, put the Phantom on your workbench, take the props off, and run it full throttle.
    This is, of course, if you believe that deep cycling is advisable for LiPo's. Most experts do not believe this to be the case. It is, however, the only way DJI suggests to keep the batteries calibrated, sooooo...
  7. N017RW
    Palm Beach Co.- FL
    Hovering works for me. At the end it can barely get above ground effect.
    Must be cautious of winds while doing so but I can see many not being comfortable with this.
    As far as discharge goes, my telemetry indicated it would no longer stay aloft below ~10.6v under load.
    Well above the widely accepted damage threshold of 3v/cell.
  8. Buckaye
    Orlando
    +1 on getting it off the charger... Saw this question in another post and didn't see a good answer - how do you all get the battery to 8% (because as someone mentioned - you certainly can't fly it to 8%). Just curious as I just got the Phantom 2 over the weekend and am wondering when I want to cycle the battery how to do it.
  9. HarryT
    Warrington, UK
    Ah, my misunderstanding. I thought he was asking how to get his fully-charged batteries down to a safe storage charge level.
  10. ProfessorStein
    Portland, OR
    Good to know!
    I still won't hover it to that point, though ;)
    That's what my table is for.
  11. N017RW
    Palm Beach Co.- FL
    Yea, not the only way to do it.
    The bench method is more convenient for sure.
  12. bcass1
    I did mean to cycle the battery down to 8% as suggested by DJI. Is there a difference of opinion on this? I googled Lipo battery care and maintenance and it mentioned cycling the battery to reduce "memory " problems.
  13. noiseboy72
    Lincs, UK
    Lipos do not suffer from memory effect like Nicads do.
    I am not sure why DJI recommend the deep discharge, but I do mine every 20 flights or so.
  14. Happyflyer
    Cold, Cold, Michigan
    Best is to sit it on your bench or deck with props on and anchor it down. Speed it up, not to max, and wait until battery is at the 8% you are looking for.
Similar Threads - battery charger Forum Date
Help with phantom 4 battery charger Phantom 4 Help Jul 21, 2017
Battery Charger for Osmo (Original) Osmo Original Jun 27, 2017
[SOLD] For Sale: Phantom 4 with extra battery, charger, props Classifieds Jun 11, 2017
For Sale-Phantom 3 Pro,Extra Battery, DJI Hard Case, Fast Charger Classifieds Jun 5, 2017
Multi-battery Charger Getting HOT Phantom 4 Discussion Jun 3, 2017
