Bang!!! Lost my gimbal :( Help needed!!!
Discussion in 'Phantom 2 Vision + Discussion' started by ncapela, Dec 26, 2014.
  1. ncapela
    Hi Guys!
    Recently I´ve crashed my Dji Phanton Vision + and the Gimbal Stopped working.
    The Flex cable is good, all seems good, but no lights in the gimbal and nothing from the software.
    The drone flys good, but lost gimbal. (the vision app gives me no feed from satellites, battery info.... Just the battery lever from range extender)
    Is it normal to loose feed from telemetry on the Phanton without the Gimbal?
    My best option now is to put an ZenMuse H3-3D Gimbal and connect it to the drone? Is it easy to do it?
    Best regards to you all!
  2. Dirty Bird
    Glen Burnie, MD - USA
    No gimbal means you'll have no telemetry. Check the three gray cables that connect to the gimbal and make sure they are securely seated. Make sure a wire hasn't become disconnected from the connector. If you've had a crash you'll need to check where they plug into the Phantom's internal circuitry also.
  3. ncapela
    I´ve disassembled the Phantom to check for disconnected wires, and other stuff. Nothing seems anormal...
    I think the main gimbal board is the problem. Almost sure!
    Next week a friend will try is gimbal in my Phantom to be absolute sure!
    Does Dji sells the Main Board? I don´t think so...
    So if that is absolute sure, the best solution is to buy an Zenmuse?
  4. Dirty Bird
    You can't buy a Zenmuse and just plug it into your Vision+. It is more involved than that, and ultimately more expensive than buying a Vision+ replacement gimbal/camera.
  5. ncapela
    I´ve seen some Threads, and the conclusion is that it works, in a vision+
    The app receives stream directly from the GoPro, but not possible to start Rec, just in manual way or from the remote.
  6. Dirty Bird
    I haven't read the latest but I believe the thread says it works within 25 meters. That's only 75'.
  7. ncapela
    You understand it wrong, that is the distance in GoPro app and remote :)
    Check:
    viewtopic.php?f=27&t=31723&p=291609#p291609
  8. RCF - DRONE
    Sylvania, Ohio
    I may be way off here, but I read something in the past tbat your very thin fragile, gps receiver in the bird is ceramic and may have suffered a crack.... which occurs often in a hard crash, I bought 4 extras, which were only 5$ from an electroinc store.... I will try and find the link, but as I recall, the person posting it, had the same issues...
  9. ncapela
    Hi RFC, the drone flys very good, the only issue is the gimbal, stopped working... The ribbon cable is good, and everything seems fine except for the main gimbal board.
    Thank you very much
  10. Larry L
    Copperas Cove, Texas
  11. justin00
    Australia
    You can buy the mainboard for like $80 new.
    I've seen it on ebay and a couple of websites.
    If you are in Australia I can show you who I use on ebay to buy new parts locally.
    Would doubt its the mainboard if everything else is working perfectly.
  12. daveth1956
    Always take care when trying a "faulty" component on a good unit, get it wrong and the fault can carry over, My previous experience shows putting a good component onto a faulty unit is more risky than trying a bad component on a good unit.
  13. ncapela
    Could you tell me where can I get the Gimbal main board?
    I´ve searched for it in the web, but no results.
    Many thanks
    Thank you for your advise Dave, I will test with a complete gimbal unit.
    Maybe my only solution is the Zenmuse... :(
Similar Threads - Bang Lost gimbal Forum Date
Lost my drone in Bangkok (( Pro/Adv Discussion Dec 26, 2015
Banggood and warranty Pro/Adv Discussion Aug 11, 2017
Banggood defective quadcopter return policy ? What should I expect ?!!! Phantom 4 Discussion May 29, 2017
Need help deciding the most Wifi Signal Bang for the Buck... Standard May 6, 2017
Banggood Good?? Phantom 4 Discussion Apr 10, 2017
