bad motor bearing
Discussion in 'Phantom 2 Vision Discussion' started by birddogg, Jan 15, 2014.
  1. birddogg
    I have had about 60 or so flights on the P2V no problems. Until last night we noticed during a motor mount check it seems a bearing has gone out. The motor appears at first to be lose from the mount but closer inspectin reveals its a little bit of play between the top casing on the motor and the bottom casing. Do you guys beleave this is a bearing issue? Or maybe something that has been there from day one and is probably ok?
  2. LandYachtMedia
    Central North Carolina, USA
    Is the play lateral or axial?
    If the play is lateral it would likely be a bearing. If the play is axial you will want to check and see if the E-clip and thrust bearing has come off the back of the motor shaft.
  3. birddogg
    Hmm not sure what you mean by that, it move's side to side not up and down. Hope that helps and thank you for the help.
  4. LandYachtMedia
    Yep. That helps. Side to side is lateral so that is a bad bearing.
    If you pull up on the prop and it moves that is axial movement.
    Squirrel! likes this.
  5. birddogg
    Ugh , maybe were gonna need two of these things for backup.
  6. LandYachtMedia
    You can order a full set and replace them as needed. When I checked the other day a set of 8 with clips (2 per motor) and thrust washers were about $15.
  7. birddogg
    Wow thanks we were under the impression we had to replace the motor, il get right on that!
  8. birddogg
    You dont happen to have a link do you?
  9. LandYachtMedia
    You're welcome. No need to replace the motor unless the bearing seizes and damages the housing or shaft.
  10. LandYachtMedia
  11. birddogg
    This is for the P2V right?
  12. LandYachtMedia
    The bearings are the same. The motor shafts are different between v1 and v2 but the bearings are not.
  13. birddogg
    Awesome man your great, have a good day.
Similar Threads - bad motor bearing Forum Date
Standard Can a bad roll motor cause gimbal to malfunction? Phantom 3 Help Jul 27, 2017
Standard P3 Std crashed, bad motor? Phantom 3 Help Apr 6, 2017
Bad motor on my 3mo old P4 Phantom 4 Discussion Dec 9, 2016
Bad motor diagnosis ? Standard/4k Discussion Nov 8, 2016
P3 can't take off straight, bad motor? Standard/4k Discussion Jul 24, 2016
