Bad AXi motor install
Discussion in 'General Discussion' started by MonsieurAnon, Nov 18, 2014.
  1. MonsieurAnon
    Melbourne, Australia
    Video of the problem; http://youtu.be/h00GlKrCYG4?t=37s
    So, my present problem is this:
    I installed 4 AXi motors, and confirmed that they worked with a hover test, but then it went into serious oscillation when it had to correct itself.
    So I decided to try using a motor adapter and 9443 props instead of the carbon fibre ones that worked with the default adapters. I went out to give it a flight today, and the front motor visible in this video doesn't start as quickly as the others ... it goes back and forth a bit before starting to spin, and then it only spins at about half the speed in idle.
    I didn't catch, or notice this before take off and I think the quad got about 10cm of air in a flipping motion before biting the grass, which seems like a logical reaction to having a funky motor. Any ideas what the most likely culprits are for this?
  2. RDCF550
    USA, VA
    Swap your CCW motors. If the problem goes to the other arm, you have a bad motor. If the problem stays on the same arm, you have a bad ESC.
  3. MonsieurAnon
    Ah, that's brilliant; a binary test. Thank you!
Similar Threads - Bad AXi motor Forum Date
Why drone taxis are bad for the drone community...Article/Pics News Mar 11, 2017
Bad battery Pro/Adv Discussion Tuesday at 4:48 AM
Standard Bad Gimbal? Or motor? Phantom 3 Help Jan 8, 2018
Standard Bad battery ? Phantom 3 Help Jan 8, 2018
Sudden bad interference - Help! Pro/Adv Discussion Jan 7, 2018
