B&H Replaced my Phantom Vision again
New Jersey, USA
Hello all,
B&H replaced my Phantom Vision again and I just received the new one. How can I tell what firmware version my TX/controller has?
Tom
tgaynor said:
Hello all,
Tom
If you turn everything on including the controller and go to the info tab I believe it's lists the controller firmware as well and tells you if it's up to date. I don't think you have to tear the controller apart unless you have to upgrade.
Here is a screenshot of the Upgrade screen and Info Screen. Am I all up to date?
Looks like I was wrong. I got tx and rx confused. You might take the controller apart and connect the micro USB that's inside the controller. I've heard there's a possibility some might have a micro USB on the bottom of the controller. Mine does not though.
Think there is a second dl you have to install and run as well. Dl on the same web page you got the assistant you have now. Assistant something.... It's called.
