aux pwm channel on the P2V+ naza?
Discussion in 'Phantom 2 Vision + Discussion' started by foobarbecue, Aug 23, 2014.
  1. foobarbecue
    I want to install a receiver controlled relay switch in my P2V+ ( http://hobbyking.com/hobbyking/store/uh ... oduct=8833 ) to control a headlamp. Physically I see there are lots of channels free on the "Phantom"-labelled NAZA. I just want to be able to set a channel high or low from the 5.8ghz transmitter. I guess this probably means using the "tilt" channel.
    Anyway, has anyone done this?
  2. foobarbecue
    Figured it out! Turns out that the "tilt" channel, AKA 7, controls the output of F2. So all I had to do was plug my receiver controlled switch into F2!
Similar Threads - aux pwm channel Forum Date
Auxiliary Lighting General Discussion Jun 27, 2017
No aux power cable on Phantom 2 Phantom 2 Discussion Jul 23, 2016
Auxiliary cable Phantom 1 Help Oct 20, 2015
Professional P3 Pro Aux output / servo / parachute Phantom 3 Help Aug 12, 2015
Does Phantom 3 have an auxiliary power cable somewhere inside? Pro/Adv Discussion May 6, 2015
