I recently purchased the Autopilot app to assist me with Dronebase pano missions.
Test pano, worked fine. However, my first real mission with it – in the stills where the camera points straight on, I got the props in the way?? I brought the drone down to a height where I could see the camera. Turns out that when I turned the gimble knob it keeps going up until its pointing straight up (thus catching the props).
I did some google searches, but couldn’t find much. I did read some articles that an IMI calibration might help. I tried this and did another test pano mission at home and it worked fine.
Today I tried two real pano missions. The first worked perfectly. But the second had the props in the way again. I haven’t tried another IMU reset, but seems too odd that I would have to keep doing IMU resets.
Any thoughts…
Update since posting:
A friend gave a suggestion to check the Enable upwards gimble tilt limit to 30 degrees". We confirmed it was not set. I went outside to do another test Pano. Low and behold it did the same thing. When I landed I checked that setting and surprisingly it is now turned on. So did autopilot do this?
Any thoughts…
