Autopilot and Orbit
Discussion in 'Pro/Adv Discussion' started by mikel101, Sep 5, 2016.
  1. mikel101
    Whenever I do an orbit in Autopilot, I get the following message:
    Operator location accuracy is greater than 35 ft, do you still want to continue?
    Does anyone know why this message appears?
  2. With The Birds
    Australia
    So you want to orbit operator? Does your tablet have a barometer? It is warning you that the position reference may exceed 35 feet so make sure you have a good error margin before engaging.
  3. mikel101
    Yes I want to orbit the operator.
    I am using an iPad mini gen 3.
    So how do I change/fix the error margin?
  4. With The Birds
    Australia
    I'd wait for others to chime in here (I haven't owned a mini 3) however I'm pretty sure it doesn't have a barometer. In the absence of a barometer the operator altitude won't be accurate.
  5. impilot51
    Now, no barometer in that iPad.
  6. CCrew
    Nope, no barometer, you're correct. Mini 4, iPad Air 2, and iPad Pro only ones that have it.
  7. Jayfdee
    Morecambe Bay UK
    Only the cellular ipads have a gps function. I have the warning with my old non cellular, but not with my newer cell model.
  8. crash1sttime
    Manchester UK
    To do any kind of operation where you the pilot are a focal point then the quad has to know where you are, if your device doesn't have GPS in it then the app won't be able to determine your location thus you get the error. I have an iPad without GPS and can't use functions such as follow me etc
  9. Rig
    Rig
    When your focus point is stationary there are ways of getting around the lack of gps on the operator. Before you engage the orbit, fly the drone over the position you want to focus on and select "use aircraft position". This will set the x and y axis for the focus point. Fly out to your radius and change the gimbal pitch to focus on your target. You've now set the z axis. Engage.
    This is a loose description of how its done. But it should point you in the right direction. Lots of tutorials on you tube.
Similar Threads - Autopilot Orbit Forum Date
Autopilot orbit waypoint Control (Go, Litchi, etc..) Apr 20, 2017
Autopilot Orbit Disengaged Pro/Adv Discussion Mar 17, 2017
Autopilot Orbit Mode Question Pro/Adv Discussion Feb 28, 2016
Litchi vs Autopilot!? Control (Go, Litchi, etc..) Jul 23, 2017
P3P + Autopilot = ??? Control (Go, Litchi, etc..) Jun 1, 2017
