Automatic flight and video transfer
Discussion in 'Phantom 2 Discussion' started by Jekek55, Nov 14, 2015.
  1. Jekek55
    As university work I need to use the drone to fly through few waypoints automatically and transfer video(realtime) to the laptop pc(windows OS).
    The drone I have to use is Phantom 2 DJI Zenmuse H3-2D with GoPro 4 camera. I wanted to transfer video directly(in realtime) from gopro camera but I have read that a phantom controller operates at 2.4GHz frequency which is the same as GoPro Wi-fi frequency. Will it work or will there be interferences that will not allow it?
    The second problem is how to set the waypoints for phantom to fly through. I have read there is android app for phantom vision but it seems it won't work for phantom version with gopro. I also don't have Ipad(for ground station app), only the android phone. Are there any other ways?
    I would appreciate any advices, solutions.
  2. jason
    Commerce Twp,MI
    You definitively cannot use the GoPro's wifi due to fact they both use the same frequency. I am not positive but I think you can do both through a ground station use lightbridge but the system is not cheap.There should be someone here who can help you with more info on a ground station.
  3. Jekek55
    So is it the dead end (lightbridge is out of my reach)? I can't understand why do they sell a drone with a camera that cannot be used remotely.
  4. jason
    Commerce Twp,MI
    That isn't correct because they do sell P2 vision+ and P3's that have there own cameras and run on a frequency of 5.8GHz using wifi to send video back to FPV equipment you just happen to have the wrong Phantom.
  5. Jekek55
    I've found this (hope it will work for the gopro4 as well), so hopefully it will allow me to stream video. Do you know anything I could use to set the travel waypoints ? (There is a PC ground station app but it seems on December 12, 2015 it will stop functioning)
  6. jason
    Commerce Twp,MI
    I have no idea what you found and hope it will work with the hero 4 because you failed to post it. But what ever it is if it involves the use of wifi you are asking for trouble as both use the same 2.4GHz frequency.
  7. johnbig
    Sydney Australia
    Hi Jekek55, The IPad ground station will continue to work after December. Also the video from the transmitter that you found will not be much compared to the video recorded onto the camera card.
  8. Mako79
    Sydney Australia
    You have the wrong Phantom to start off with.
    But yes, there are work arounds but at a cost and headf*ck.
    You need 2 way coms (uplink and downlink) for Groundstation to work. You can get a BTU24ghz (I heard they are discontinuing this due to the map system - google maps vector graphics or something).
    You can get a plug and play AVL58 transmitter and receiver with RCA output. You will need an RCA to digital input card on your laptop.
    BTU24 Ghz
    DJI IOSD 2.4G Wireless Bluetooth BT Datalink & iPad Ground Station & BTU i
    AVL58 Transmitter and receiver.
    http://download.dji-innovations.com/downloads/phantom_2/en/5.8G_VideoLink_User_Manual_v1.0_en.pdf
    RCA USB Capture card
    Premium Capture Audio Video Adapter Card TV VHS DVD EasyCap DC60 USB2.0 PS2 XBOX
Similar Threads - Automatic flight video Forum Date
SafeSky.online automatic DJI flight logger Flight Data Analysis Mar 21, 2017
DroneDeploy Automatic Flight Syncing General Discussion Dec 8, 2016
Automatic Photos During Flight Phantom 4 Help Nov 19, 2016
automatic gps flights with Phantom 2 Phantom 2 Help Oct 20, 2016
Question - Automatic flight mode change Phantom 2 Vision Discussion Dec 2, 2013
