Auto land - signal loss <50m. from home?
Discussion in 'Phantom 2 Discussion' started by cengiztanc, Jan 25, 2015.
  1. cengiztanc
    I have a brand spanking new P2V3, with zenmuze, an immersion 600mah, mini iosd FPV setup, all with the latest updates.
    On my maiden flight the drone switched in to fails safe mode and proceeded to fly back about 30meters away from my location. I recovered the controls by switching S1 to failsafe and back to GPS.
    Further testing is revealing a consistent tendency to enter FS mode, ascend to 20m, fly back home, at around 30-50m from my home location.
    The FS settings in the Phantom assistant are at 120m altitude and 1600m distance. I don't understand what is happening?
    I've tried this with the immersion TX powered on and off, I get the same thing.
    Please help!
    Thank you
  2. N017RW
    Palm Beach Co.- FL
    Well two things can cause RTH, low battery if you have it set for such (with the assistant s/w) or los of control signal.
    Low battery condition/situation should coincide with red flashing lights under the arms
    Loss of signal can commonly be local interference or an actual issue with the Tx or Rx side of the system.
    Try futher eliminating possible on-board sources of interference by turnng off all accessories and inspect your antennas and connections.
  3. cengiztanc
    Definitely not a low battery. I will try turning off more accessories, which I guess means disconnecting the mini iosd as well as the video transmitter. Is there anything else I can turn off?
    Thanks for you help
  4. N017RW
    Palm Beach Co.- FL
    Everything you can to be sure you've covered it all.
    Next I'd be looking at antenna cables and connections.
Similar Threads - Auto land signal Forum Date
Litchi "Low Battery" during mission (with good signal) - Auto Land or RTH? Control (Go, Litchi, etc..) Sep 3, 2017
Had a fight with 'auto-land' Pro/Adv Discussion Dec 2, 2017
Autolanded at 20% Phantom 4 Pro Discussion Oct 27, 2017
The first autonomous drone delivery network will fly above Switzerland starting next month News Sep 20, 2017
Litchi going to auto-land after 3 canceled RTH. why? Control (Go, Litchi, etc..) Sep 3, 2017
