Mooringmaster said:
Many thanks for the info. Have enabled IOC. This should help my flights alot as I am always lossing sight of it and rely on shutting tx off to get to come back to me. Again.......THANK YOU!!!
Personally, I would save shutting off the TX for only when you really need it, so its good that you can use IOC instead! Just a hint of caution about the S1 and S2 switches in Naza mode. If you're not used to them, it's easy to forget about them. And the Phantom will behave very differently in each mode which can be confusing if you're not expecting it.
I stupidly sent my Phantom into a brick wall by switching from ATTI to manual (yikes!!!) instead of back to GPS (brain lapse). Fortunately, I had already had a run in with a palm tree the week before which meant the gimbal wasn't mounted at the time otherwise I'd be shopping for a new one!
Pmcdn said:
So just to be clear, if I fly in vision mode (NOT naza mode) with the left switch down to lowest position, it will still fly normally and in GPS mode EXCEPT it will fly back to me (home) when I pull the right stick back, regardless of its orientation?
I'd like to experiment with this home feature, but only want to fly in GPS mode.
Correct. You will still be in GPS mode so the Phantom will hold its position in the wind and stop when you center the sticks. It will simply maintain a line to your home point. You can even yaw and it will maintain that line which is useful for filming.
