Arrow not pointing where I'm flying
Discussion in 'Phantom 2 Vision + Help' started by xtragrouse, Feb 15, 2016.
  1. xtragrouse
    Hi, I have a P2 Vision Plus, Samsung Tablet which doesn't have a compass, and I am using Vision App. When I study the unit sitting on the ground facing away from me pointing South for example, the arrow is pointing in a direction which is the opposite of the Compass Icon in the top left corner. If I rotate the copter 45 degrees to the right, then the arrow shows which direction I am pointing in relation to the icon, which is the East, not the direction that the camera is facing. I want it to point in the direction that I am flying, in other words in the direction that the camera is facing, so that I can see whether it is flying to me, away from me or whatever. I have searched for answers and people are talking about maps and calibrating this and that, but I can't see where any of the answers relate to what I am trying to achieve.
    From the manual; "If your mobile device contains a compass, the top portion of the Radar is the direction you are pointing. If not, the radar will be oriented due north" which it appears is the case here. Will a compass App help solve this issue? All I want, is to have the arrow pointing in the direction the P2 is facing, not it's relationship to due north.
    Does this make sense? HELP :)
  2. fordruid
    Wisconsin
    Sort of. Try Field Compass app and see f it helps
  3. Mark The Droner
    I have a similar problem and my tablet doesn't have a compass either. I've concluded I need a new tablet!
  4. dirtybum
    I use iphone 5s and it points the wrong as well although ive never paid attention if ifs pointing north, i'll have to check. I'm pretty sure used to point the right direction with the same phone. Don't know if it stop doing that since I updated the app or not but something changed. And should an iPhone 5 have a Compass.
  5. Palliz
    Next time you power up everything & before you fly just take your tablet & believe it or not just work it around & around like a figure 8 a couple of times then check again.
    I know it sounds crazy but I have to do it sometimes so that the compass resets in your tablet - PRESTO it will work!
  6. Mark The Droner
    How can the compass reset in the tablet when there is no compass in the tablet?
    kirk2579 likes this.
  7. Air Ontario
    U.S./ Canada
  8. RayH
    Chester UK
    Check the arrow in the map view hasn't got a lock symbol on it, if it has press it and unlock it.
  9. xtragrouse
    Thank you everybody for your replies. I will check the firmware update, and download a compass into my tablet and see how we go from there.
  10. Mark The Droner
    Yeah - I don't think it's possible to download a compass to a tablet that doesn't have one, but if you can figure it out, that would be great!
  11. xtragrouse
    You are right as far as my Tablet is concerned - no magnetic sensor. However, the phone has, so we shall see. Another problem, I loaded the Assistant and no connection, altho the PC tells me that it is plugged in, but doesn't show on the computer either. Might try the Macbook and see how I go.
  12. kirk2579
    Girard. ohio
    Bingo
    compass needed for that!
  13. kirk2579
    Girard. ohio
    did you install the pc driver for the usb connection with quad
    dirtybum likes this.
  14. Helijoc
    I have the same problem with my Samsung Tab 4. It does not have a magnetic sensor.
  15. kirk2579
    Girard. ohio
    what same problem @
    no connect to pc
    or compass issue?
    if your tab 4 has no compass or it is not working the app cannot show that info correctly then.
    that simply means the tab is not completely compatible with all app features.
    I don't have that model so I don't know if it does
Similar Threads - Arrow pointing where Forum Date
Standard I think I have got my gimbal problem narrowed down. Phantom 3 Help Jul 14, 2017
directional arrow help please Phantom 4 Pro Help Jul 7, 2017
Long, narrow alignments Surveying and Mapping Jun 22, 2017
Litchi - Narrow sensing (hold) P4P Standard/4k Discussion Apr 9, 2017
The Back River, Arrowsic Maine Photos and Video Mar 27, 2017
