Are the batteries the same?
Discussion in 'Phantom 2 Vision + Discussion' started by MapMaker53, Nov 14, 2014.
  1. MapMaker53
    Long Island, NY
    Hi guys,
    I've currently got 4 batteries but feel I could use a fifth battery at some shoots in order to capture all aspects of the field work. (The sites I fly are often large.) Do the Phantom 2, Phantom 2 Vision, and Phantom 2 Vision Plus all use the exact same battery? So far, I can only find a battery bundle (2 batteries plus charger) locally for a P2V+.
    Thanks.
    Bill
  2. happydays
    Warrenpoint, Ireland
    I have a P2V and a V+ and both fir and work. The only difference is the data pads on the P2V batteries are small and round while the V+ has larger square terminals.
  3. N017RW
    Palm Beach Co.- FL
    All the P2 variants use the same battery.
    The data pin/pad size and shape reference by happydays indicates battery revision of sorts.
    The smaller round pads are the older style while the larger square pads indicate the newer style.
    Other than that there are no published differences in the two revisions that I recall.
  4. MapMaker53
    Long Island, NY
    Thanks for the quick replies. I just called B&H Photo and it turns out they sell single P2V+ batteries too (but only show the bundle in the web search). So I'm all set. But good to know those two are at least compatible.
  5. happydays
    Make sure they have the big data pads :D :D :D
  6. MapMaker53
    Long Island, NY
    Yes, I will check the pins when I get them to make sure they are the flat ones. My other 4 batteries have the flat pins, which I'm sure make better contact.
  7. N017RW
    Palm Beach Co.- FL
    What am I missing?
    The pins are in the quad, the pads are on battery.
    The pins have (also) changed from dome topped to crown or multi-point topped but that was beyond the OP's question.
    Finally, it's doubtful there's any round pad batteries still in sales queue.
  8. MapMaker53
    Long Island, NY
    Sorry. Meant the flat contacts on the battery.
  9. N017RW
    Palm Beach Co.- FL
    No probs. ;)
    Just wanted to be clear on the info.
    Bad info is worse than none sometimes.
Similar Threads - batteries same Forum Date
Is P4P the same batteries as P4? Phantom 4 Discussion Dec 31, 2016
P3S Batteries - Same as Advanced, 4k , or Pro? Standard Sep 25, 2016
Phantom 4 charge hub - multiple batteries at same time Phantom 4 Discussion Jul 11, 2016
Same Batteries P3 Advanced and P3 Pro? Can Get Better Charger P3A? Pro/Adv Discussion Nov 28, 2015
Charge 3 Phantom 3 batteries at the same time in 90min Standard Sep 10, 2015
