anyone think it's difficult to remove the P2V's battery?
Discussion in 'Phantom 2 Vision Discussion' started by trwalp, Nov 27, 2013.
  1. trwalp
    I find it difficult to pull the battery from the Phantom 2 Vision. I believe I'm pressing in enough on the two latches; the problem seems to be friction or that the battery is too tight for the space allocated. I'm wondering if anyone else has this experience and has figured out a solution. Thanks.
  2. Migmon
    I agree it can be a ***** to remove sometimes
  3. iDrone
    Los Angeles, California USA
    I use both thumbs (below) & index fingers (above) to squeeze the tabs, then rock the sides of my hands against the body of the Phantom as a backstop to pull the battery out. Once it clears an inch or so you can grab it with one hand.
    iDrone
  4. Pull_Up
    South Oxfordshire, UK
    Yep mine is stiff to get out, too. I wonder if this is why I never got the invalid battery error - everything is held very tightly so not much room for those spring-loaded pins to dance about and lose contact.
    It will be interesting to see if my second battery is also a good tight fit when it arrives.
  5. trwalp
    Thanks to all for replying. My goal was to calibrate expectations, not criticize the battery.
  6. Pull_Up
    ...and for the record my second battery is also a good tight fit (although perhaps a little easier to remove than the one it shipped with). Looks like tight is where it's at. If my fingers are cold I do find it very difficult to remove. Must get some dielectric gloves so I can still operate the app with them on!
  7. PAValentine
    Ft. Worth Texas
    In one of the DJI video's Colin mentions the tightness of the battery and indicates that it is that way on purpose. So it won't come out in flight.
Similar Threads - anyone difficult remove Forum Date
Anyone heard of Pegasus Aeronautics? General Discussion Saturday at 12:34 PM
Has anyone had any luck using the Pro+ Editor in the built in screen version of the P4+ Phantom 4 Discussion Thursday at 8:23 PM
The Litchi app: Anyone had or still has it? For how long and do you have any remarks about using it? Control (Go, Litchi, etc..) Aug 16, 2017
Myrtle Beach anyone? Southeast USA Aug 13, 2017
Help! Lost a part during repair, can anyone identify the part? Phantom 4 Pro Help Aug 10, 2017
