Anyone successfully waterproof a Phantom?
Discussion in 'Phantom 2 Vision + Discussion' started by dannytroy, May 10, 2014.
  1. dannytroy
    Westchester County, New York
    I'll be using my Vision+ almost 100% over water and was wondering if anyone has successfully waterproofed theirs. I coated the compass using Liquid Tape, and it seems to not be affected by the coating. As far as the rest of the electronics, it looks like a really big job to disassemble enough to get at all the parts.
    I was thinking of using CorrosionX on the circuitry, but since the altitude sensors can be damaged, that is a major concern. Not wanting to coat those sensors. That is located in the Naza board, correct?
    The other major area of concern is the gimbal and camera. Those brushless motors look delicate enough that I wouldn't want to put any coating on them which might cause them to malfunction. As far as the camera, I don't know how that will take to a submersion in water.
    Basically, I would like to keep it out of the water if at all possible, but if it does wind up in the water, I'd like to minimize what would need replacing.
    I'm designing a float gear that will minimize flipping after landing.
    Any ideas, other than suggestions to not fly it over water???
  2. CarlJ
    Peru, Indiana
    I have a friend that is obsessed with the idea, I gotta admit I am as well. I've seen a few things on youtube and on the web, but nothing really tangible.
    I wish you great success, the person that figures that out is sure to make a lot of money.
  3. dannytroy
    I will start by coating the esc's with CorrosionX. The motors don't really need waterproofing, and re-oiling after dunking usually is all that's needed. I have the compass taken care of. It's a matter of tackling each part individually, minimizing what needs to be replaced, in case of water damage. The camera/gimbal is a huge problem, and probably the most expensive part to replace. Don't know about the GPS antenna, but read that it usually does ok after drying out.
    I'd like to know if there is circuitry in the gimbal, or if it gets it's signals from the Naza-M board. Although a long time fixed wing r/c'er, I'm completely new to quads, so this is uncharted territory for me. Definitely gives me something to do on rainy days though, since I am semi-retired!
  4. Geoelectro
    Houston Tx.
    My P2V was in a lake for about 30 minutes 5 or 6 weeks ago. I lost the camera and battery. Never found the camera. The battery was damaged by the soaking. Dried out the quad and it flew again. Unfortunately the quality of flight began to decline. A week and a half ago I took it apart again for additional cleaning. I found the motors now have a slight amount of rust in them. I also suspect the NAZA module had water in it which may be the cause of the decline of stability. I opened that module and discovered it is not water tight. Some delicate components inside as well. The GPS and main control board seem fine. ESC's seem fine. I believe replacing the 4 motors and the NAZA should restore it.
    The motors internals should be coated if possible. The NAZA module could be better sealed. No idea about the camera/gimbal, that one is tricky.
    Geo
  5. Sketch6995
    Colorado, Western Slope
    the answer is yes, a company called liquipel, they have a video that is quite remarkable, they completely submerse their phantom and it flies away still dripping water, heres the link.
    https://www.youtube.com/watch?v=h3pU0XKQZt4
  6. MikesTooLz
    Miami, Florida
    DSLRPro sells liquipeled Phantom 2 visions that are made to be waterproof.
  7. Sketch6995
    googling but cant seem to find, got a link? just bought a P2V and have another 2000 sitting around.....thinking about the P2V+ but would love a liquipeled one lol
  8. MikesTooLz
    Miami, Florida
  9. dannytroy
    Yes, I had seen that video before I posted my question. Looks good, but you have to send them the unit and they will do the waterproofing. The price for waterproofing a tablet PC is 60.00 to 80.00, so I'd guess the Phantom would be quite a bit more. I wonder how different it is than just using CorrosionX. And how do they deal with the internals of the Naza module (which can't be sealed), and camera/gimbal. I've been flying brushless on floatplanes for years, and they do real well after submersion. I never had one fail due to water related damage.
    Anyway, I just completed my new float gear, and hopefully will keep the electronics high and dry (famous last words!)
  10. UrAwFuL
    Los Angeles, CA
    Me want! Me want! :shock:
  11. Sketch6995
    thanks mike... :D sketchy reaches deep into his pocketses :mrgreen:
    OH BALLZ!!!!! not currently available.....ok so sending mine in as soon as i get the P2V+...gotta have something to fly.
    [​IMG]
  12. dannytroy
    Well, this is the float gear I came up with, for a start at waterproofing. That, and the liquid tape coating on the compass. I used 8mm carbon fiber for the frame, and thin solid CF pegs that go through the floats at the ends of the CF tubes. The total weight of the floats are 2.8oz. That weight was more than offset by using CF props and taking the prop guards off. I'm hoping it's stable enough on the water.
      File size:
      136.8 KB
      266
      File size:
      171.8 KB
      209
  13. CarlJ
    Peru, Indiana
    A lot of surface area on that landing gear Danny. Have you had a chance to test them in the wind?
    And I saw somewhere some guy working on a waterproof shell that floats. I'm not sure if anything became of it, but I really think he was on to something.
    https://www.youtube.com/watch?v=ESIEWURYNPc
  14. Dagenvan
    The Netherlands
  15. MikesTooLz
    Miami, Florida
    What are you planning on doing? Fishing with it?
    [youtube]http://www.youtube.com/watch?v=yFr0m1MTYuo[/youtube]
  16. dannytroy
    So far I've only tested it in my small backyard. It seems to fly fine, as long as the prop guards are off. I'll give it a good test at the lake this coming week.
    I probably should have gone with a completely waterproof quad from aquacopters.com
    They have an RTF with motors and ESC's installed for $350.00. Problem is, by the time you're done equipping it like the P2V+ it's more $$$ than the Phantom. Still, I can see it in my future, and use the Phantom strictly for land use.
    And Mike, yes I had seen that fishing video on Youtube. Pretty funny.
Similar Threads - Anyone successfully waterproof Forum Date
Has anyone successfully launched a mavic from a flying P4 Off Topic Feb 10, 2017
Is anyone successfully using a Galaxy s7? Pro/Adv Discussion Aug 5, 2016
Has anyone linked the P3P transmitter to the P4 successfully? Phantom 4 Discussion Jun 5, 2016
Standard Has anyone successfully unlocked a NFZ? Phantom 3 Help Mar 24, 2016
Has Anyone Successfully Registered A Canadian Drone with FAA? General Discussion Feb 27, 2016
