I have a new Phantom Vision and trying to understand the path it will take during the "going home" procedure.
Can anyone explain the following examples?
1) If the home point is up on a hill at 200 feet high and I'm flying from that point and actually fly lower, say down the hill 100 feet... and if "going home" is activated, will the Phantom fly all the way back up to the correct height?
2) When landing at the home point, is it a soft landing? Does it stop based on altitude or it can tell when it touches down?
3) If you take control during a "going home" procedure by moving the right switch to the middle position... I understand you are now off of GPS?? If you move the middle switch back up to the top position, is GPS reactivated and will it "go home" again if needed" ?
On my first flight today, after landing and then shutting off the remote control, I accidentally activated "going home" and the Phantom too off from having already landed... which really surprised me. I would have thought that if it landed it would at least stay there since it was safely on the ground. Anyhow, I guess I won't turn off the controller until after the Phantom is off.
That's all for now. Appreciate any replies to above questions.
thanks...
thanks...
