I just installed the new firmware.
In the Basic / RC screen of the new assistant is has two choices under "Transmitter Version":
- Upgrade Version.
- Basic Version.
If I hover my mouse over the choices the Upgrade option shows the brand new controller with the wheel control for tilt. If I hover over the Basic it shows the manual tilt lever installed on the back. This is my configuration. I added the tilt lever to my P2V+ controller.
However, with Basic selected the lever does nothing. If I select Upgrade the lever works but the tilt is only controlled through a narrow range of perhaps 30 degrees. When Upgrade is selected the same is now true for trying to control tilt through my iOS app. That is the tilt can now only be controlled over a short range. I can't point fully up to look straight out in front or fully down. Tilt from the iOS app works fine for Basic. Just no lever control...
So, anyone got the tilt lever to work with the new firmware?
Is there some calibration I missed (I don't see any for the 7th channel...)
Thanks!
- Upgrade Version.
- Basic Version.
Thanks!
