Anyone get jello?
Brand new Pro. You think I should get some carbon fiber? I have 2 standards never had this happen. I also was wondering if anyone has video files corrupting on new video file overlaps? Like I said with the standards I never experienced any of this.
The DJI carbon fibre ones are no more likely to be balanced despite what the description implies.
I've found all props significantly out, enough to cause some jello when fighting wind or ascending rapidly - when the motors work harder - and balancing the props more or less eliminates it.
Ignoring vibration is a likely risk factor in cracked plastic I suspect.
Plastic or carbon reinforced: you should check all props for balancing and correct them with a good balancer like du- bro.
wkflysaphan4
