Anybody using a RF-V16 for tracking?
Have a few questions about it if your using one. Thanks
That's one of the commonly used trackers. Post up your questions.
Reactions: nix240z
What sim do u use? I have AT&T should I go get a sim from there with a monthly fee or is there another way?
I used the H2O sim with the tracker on my P2V+. I never needed it, but good peace of mind at the time. ;)
One problem I had, after fussing with the RF-16 setup, was cellular coverage was lacking in many places I flew. Between Sprint (phone) and the SIM, I'm not totally confident I could have actually contacted the tracker had I needed it.
I retired the RF-16 and use a Marco Polo which costs nothing, month to month, and doesn't need cellular.
I just got a att sim put it in and it keeps telling me offline and not enabled? Any ideas???
I used these setting on the h20 sim, which is an ATT network.
Text each of the following commands:
<password>,sos1,<phone number># (sets master phone number. fyi, default password is 123456) if you do it right it will text you back. dont include the < or > in the text just use numbers and no caps all lower case.
lag,2# (sets language to English)
apn,att.mvno,user,,pd,,pip,66.209.11.33,pport,80# (updates the APN)
thats the keyboard it gives me won't let me use letters
no you have to text it to whatever phone number your sim card is from your main phone which will be your sos1 number.
for example sim card number is 888-999-9999
from your main phone text to sim card number 888-999-9999
123456,sos1,your main phone number #
if correct you will get a text back from your simcard phone number
Reactions: stulpin300m
Wow great help I would have never figured that out!! Thank you very much.
did you send these text ?
It still says offline and not enabled in the app. I called it and it called me and if I text a command it text me back the info. Is there something else in suppose to do to get it online?
when you text this apn,att.mvno,user,,pd,,pip,66.209.11.33,pport,80#
did you get a text back that Apn set successfully! reboot system now?
ok you should be able to use it on app if APN is updated. Try rebooting the rf-v16 and then the app by logging out and back in.
send it a text dw#
it should respond with its gps location.
shimuafeni fredrik
