Any thoughts on T-Motor?
Discussion in 'Phantom 2 Vision + Discussion' started by Andrew303, Jul 16, 2014.
  1. Andrew303
    Austin, TX
    I have balanced props and gimbal keeps shuttering. Was thinking it could be a motor or motors. No crashes and no hard landings. Ideas?
  2. cahutch
    Sonoma County, CA
    Any noticeable vibration when the motors spin up without props?
    If not, it could be a gimbal problem.
  3. Andrew303
    Austin, TX
    Shutters when giving full power going up.
  4. Andrew303
    Austin, TX
    The whole gimbal assembly shutters
  5. Dirty Bird
    Glen Burnie, MD - USA
    I'll give you my take, and if you've already installed them I'm sorry but you may not like what I have to say. I think they are a complete waste of money. They offer a modest improvement in performance, provide an almost imperceptible increase in flight times, and they cost TWICE as much as standard motors. It is, of course, up to you if you think its money well spent.
  6. cahutch
    Sonoma County, CA
    On the ground, with the props removed, if you start the motors and there's vibration, then the motors are unbalanced.
    If there's no vibration, then put the props on and test again.
  7. anchorkee
    U have to Tune down the gains as the motors have more juice as compared to the stock motor.
    Try tuning down pitch n roll to 100%.
    Or u can tune the attitude gains down from 260 to abt 160..
    As for me, I like the performance better as compared to the stock. I climb much faster n turn sharper. But if it's for fpv only then stock is good enough. But I like the looks!
    In addition, becos t motors have more power, unbalance props tends to stand out more. Make sure u props are balanced too.
Similar Threads - thoughts Motor Forum Date
Crashed into trees - Broken gimbal and thoughts on replacing the motors Pro/Adv Discussion Mar 23, 2016
ANTI gravity motors thoughts? id like more power captain! Phantom 2 Discussion Mar 14, 2015
Your thoughts? Phantom 4 Pro Discussion Aug 1, 2017
Heretical Thoughts General Discussion Jul 30, 2017
Your thoughts about the future Phantom? General Discussion Jul 27, 2017
