Any difference between P3P/P3A body and the P3S body?
Discussion in 'Standard/4k Discussion' started by JKDSensei, Dec 2, 2015.
  1. JKDSensei
    USA
    I don't have a Standard. Is everything the same as far as the exterior?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The exterior is very similar, but not identical.
  3. JKDSensei
    USA
    Could I use a Carbon Fiber leg brace from a P3P on a P3S ?
    Landing gear identical?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    DJI has different part numbers for the P3S and P3A/P3P landing gear, so something about them must be different. If the seller says the leg brace will fit the P3S, then all should be fine.
    JKDSensei likes this.
  5. Steve Warren
    I might have this backward, but I believe the Standard has a compass sensor in one leg and a radio antenna wire in the other that the Advanced and Professional do not because they use the Lightbridge system instead of the Wi-Fi system of the Standard. So no, the landing gear would not be interchangeable.
Similar Threads - difference between P3P Forum Date
Difference between P3P and P4? Pro/Adv Discussion Mar 23, 2017
Differences between early P3P and current model? Pro/Adv Discussion Dec 3, 2016
Difference between P3P 60 Mbps video bit rate vs P3A 40 Mbps Pro/Adv Discussion Nov 1, 2015
The difference between the English & China version batteries Pro/Adv Discussion May 15, 2017
Difference between p3 and p4 motors Phantom 4 Pro Discussion Apr 26, 2017
