Antigravity Tiger motors
Discussion in 'Phantom 2 Vision + Discussion' started by Scottrod, Apr 21, 2014.
  1. Scottrod
    Fleetwood, PA
    Well, it's pretty sad but I found a set of brand new Tiger motors and had them shipped to my door before I received my P2V+. Oh well, something new to tinker with.
    I only bought them because they were half price. Otherwise I don't think they are worth the money. I'm definitely interested to see the difference in performance though.
  2. CRankin
    Was this a one-time deal, or is it a store that's offering a sale? I don't think they're worth the nearly $200 for a complete set, but for around $100 I might consider taking the plunge.
  3. Scottrod
    Fleetwood, PA
    Sorry. I set an alert on eBay for "MN2214 920KV" AKA the motor set part number. It ended up popping up for around $110 shipped brand new unopened buy-it-now and I couldn't resist. I'll post the results if I notice any. I'm thinking they might help to increase flight time slightly but I don't think any performance gains will be noticeable.
  4. Cr8tive_leo
    Ontario, Canada
    you need to buy new props and prop nuts too.
  5. DBS
    DBS
    Ft. Pierce, Florida
    I saw a direct comparison youtube video that showed flight time gain of almost exactly one minute... and on climb rate the tiger drone beat stock at full throttle from lift off to 30 feet by about 5 or 6 feet.
  6. GhostMaster
    Last T-motors wore not so good, i would not thrust them. SunnySky are great for the price.
  7. Scottrod
    Fleetwood, PA
    Why would you? Stock props fit them fine.
  8. BenDronePilot
    If you got T-Motors for half price it probably was used and the older version that does not have self tightening prop support compatible with the Phantom 1.1.1 and Phantom 2. The current version 2.0 T-motor for the Phantom is $189 on amazon
  9. Scottrod
    Fleetwood, PA
    Nope. Newest version. Someone was unloading them.
    [​IMG]
  10. BenDronePilot
    Cool, yeah I see V2.0 on the sticker there. Hopefully they're legit. Were they advertised as new or used? How do you plan on mounting them? I just got a new set from Amazon.
    My unboxing and overview of them can be seen here for those interested. http://www.youtube.com/watch?v=oVR1zkqRDwA
    I've been debating how to install them. Like soldering directly to the ESC's as the original vs cutting and crimping, or adding bullet connectors. I decided the most reliable connection would be soldering straight down, or using bullet connectors (which also requires soldering) if I thought I might be swapping motors regularly. I think I've settled on just soldering as the originals are. Ideally all the originall solder should be removed and new solder applied. But I think I'm going to go with what some others have and try to reuse the existing solder. If not enough existing solder is left then I'll just remove it all (using a de soldering braid and pump) and start fresh vs mixing solder which I'm not so sure will lead to as reliable a solder joint.
    My reasons for replacing the motors are because I need to do them anyway, 3 of 4 of my motors are making a little extra noise in them (though the P2 does fly fine despite that) but to be on the safe side I wanted to swap them with new motors. If I'm going to the time, trouble and expense of replacing the motors it made sense to go with something a little better that should last longer.
  11. Scottrod
    Fleetwood, PA
    Yeah definitely makes sense to upgrade if you have to replace them anyway. I was planning to install them with a direct soldier joint on the board instead of soldiering the wires together. Not sure which is better or safer. The motors I got are new unused but the package was opened. They don't show signs of having ever been used or soldiered so I'm confident with them. Seller had good eBay feedback too.
    Make sure you use electronics soldier, which I believe is called B Rosin.
  12. BenDronePilot
    Mine were sealed. You can check out my video and compare mine to yours to see they look the same as well as the end of the wiring leads. They're "pre tinned" with solder already applied to them. And yeah I'll be using Rosin core solder should I end up replacing all of the original solder.
Similar Threads - Antigravity Tiger motors Forum Date
FS: Tiger Motor Antigravity MN2214 920KV Classifieds Oct 8, 2014
Professional tmotors antigravity v3 motors on p3p Phantom 3 Help Jan 31, 2016
T motor mn2214 antigravity on p3p Pro/Adv Discussion Dec 19, 2015
9x3 Antigravity T-Motor Phantom1 - Phantom2 Prop Set Carbon black Classifieds Sep 6, 2015
Antigravity t-motor MN2214 vs DJI 2312 Motors Phantom 2 Vision + Discussion May 29, 2015
