Antenna recommendations please!!
Discussion in 'Phantom 2 Discussion' started by Bugatti, May 25, 2014.
  1. Bugatti
    Hi all! I keep on reading about people going 3Km with solid video feed on monitor!!! I would be THRILLED with 0.5Km of solid video feed to my Lilliput monitor!
    Ditched the internal receiver in Lilliput 664/W and hooked up DJI AVL58 RX to Lilliput. Signal coming off AVL58 RX on P2 with DJI cloverleaf antennas on both. I loose reception at about 20m and I am out in the boonies ...acres and acres of nothing around!!!
    I actually get crappy signal on internal RX of Lilliput while the AVL58 has crapped out! For those with similar setup please help with recommendations. Thanks!
  2. wkf94025
    Bay Area
    Since you have spent substantially more on your Lilliput than your VTx, I would buy an ImmersionRC 250mW VTx and any good helical or patch antenna. Getfpv.com has been very helpful for me.
    Kelly
  3. Bugatti
    I have the Lilliput with the frequencies for the AVL58 ...will that monitor work with the ImmersionRC 250MW VTx? I do not mind spending more money ... I just want a solid video signal. Thanks!
  4. IrishSights
    Bangor, Northern Ireland, UK
    See this post as well. Always good to check if your topic is already out there.
    viewtopic.php?t=16266
    Sent from my Galaxy Note 8
  5. d4ddyo
    everyone always has issues with AVL 58 and boscam.
    I have the AVL 58. Boscam 5802. Manually tune.. don't scan. find best channel. i'm not sure about your tx but i know boscam doesn't necessarily play well with some other receivers. I know my 5802 doesn't match well with immersion.
    That being said.. assuming you can tune properly. Check out FPVLR.com and chat with him about antenna selection. He's awesome. if you are in the states. If you want .. check out Horizon in UK.
  6. Bugatti
    My main issue right now is the dismal performance between the AVL58 Tx and Rx!! They should work together flawlessly! Is anyone having good performance with this combo? If so please let me know what antennas you are using. Thanks!
  7. d4ddyo
    I DO. I told you where to check. I'm getting 2 km+ regardless of orientation. I have Circular Wireless Helical on Rx. Tx using LHCP 5.8GHz Pinwheel from FPVLR.com
  8. Bugatti
    Thanks for your help d4ddyo .. but from your post you seem to be using your internal Rx of Boscam 5802. Do you think your antenna selection will give similar results with my AVL58 Rx. I will reach out to FPVLR.com. Thanks again!
  9. d4ddyo
    yes.
  10. d4ddyo
    LOL. My bad!!! i cut and paste the wrong one. I meant RHCP 5.8 GHZ tx Pinwheel 90° SMA. You may want to use extended legs because this thing is LONG. good because it extends below the gimbal and regardless of orientation the gimbal doesn't get in the way of the transmission. OH I forgot. Make sure for the AVL58 you specify RP-sma for the connector.
  11. Bugatti
    Can you set the pinwheel antenna at about a 45 degree angle to the side so I do not have to get extended legs for P2?
  12. d4ddyo
    You can do whatever you want lol. I would go straight back
  13. Bugatti
    I also see on FPVLR.com they have the white slightly shorter antenna ..which the claim to be same 1.7dbi. I might get that. I already ordered the Circular Wireless Helical! Thanks so much for all your help. I REALLY appreciate it!!
  14. d4ddyo
    yeah... i would go down and angle it towards the back but get it as far below the gimbal as possible... just saying. I hate losing transmission when I'm flying home.
  15. Bugatti
    @FPVLR - Just ordered the RHCP 5.8GHz Tx pinwheel 90 SMA. Thanks!
  16. d4ddyo
    Now be patient. Everyone wants a fpvlr antenna. Lol
  17. d4ddyo
    Well I just want my antennae when I order them... LOL. from now on i'm putting d4ddyo on all my fpvlr orders.
  18. Bugatti
    There is THAT much a wait? It said in stock on the web site ..so I assumed they were ready to ship ....
    Also in the box that says Frequency ... are we meant to write something ... need mine for the DJI AVL58 Tx ... Order #342.
  19. d4ddyo
    He expertly crafts them.
Similar Threads - Antenna recommendations please Forum Date
5.8Ghz Omni Directional Antenna Recommendations Anyone... Standard Apr 6, 2017
Standard 5.8 Ghz Omni Directional Antenna Recommendations. Phantom 3 Help Apr 5, 2017
Antennae Recommendations? Phantom 2 Vision Discussion Jul 7, 2014
Looking for a good hi-gain antenna for my P3 SE Pro/Adv Discussion Yesterday at 9:31 AM
Standard Phantom 3 Standard with professional antennas. Phantom 3 Help Tuesday at 11:27 PM
