- Joined
- May 9, 2016
- Messages
- 15
- Reaction score
- 1
- Age
- 62
Does anyone know which landing gear antenna goes to which pin on the board located under the sonar? There are for pins numbered on the board 1-4. I had to replace the shell yesterday and in lieu of removing each antenna fom the gear i elected (dumb me) to remove the sonar cover and circuit board and disconnecting each pin from the board itself. thought it would save time by not switching out gear. Now I'm getting a compass error and won't calibrate. I keep getting strong electrical interference error. So either I damaged the compass cable, connector or compass itself, or the compass is being adversely effected by the attennas from each leg being attached to the wrong pin on the board.
Any help or suggestions would greatly appreciated. FYI- the aircraft simply sits and beebs twice constently and rear LED's blink red to green front LED's solid red. firmware on bird and remote are both up to date.
