Trackman1...so you are saying that a "full flight" (15-18 minutes?), uses 650mb?
It was capture by Unlimited Screen Recorder (free)
Unlimited Screen Recorder - Android Apps on Google Play
Thanks...
Bill
Here is the complete file info from an 18min recording done at 5000Kbps. 1728 x 1280. File size 647MB
General
Complete name : D:\My Documents\My Pictures\2016\02\6th Flight Pilot View.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 648 MiB
Duration : 18mn 6s
Overall bit rate : 5 000 Kbps
Encoded date : UTC 2016-02-17 16:24:35
Tagged date : UTC 2016-02-17 16:24:35
com.android.version : 6.0.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L4
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=31
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 18mn 6s
Bit rate : 4 982 Kbps
Width : 1 728 pixels
Height : 1 080 pixels
Display aspect ratio : 16:10
Frame rate mode : Variable
Frame rate : 28.708 fps
Minimum frame rate : 1.164 fps
Maximum frame rate : 409.091 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.093
Stream size : 645 MiB (100%)
Title : VideoHandle
Language : English
mdhd_Duration : 1086654
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Duration : 18mn 5s
Duration_FirstFrame : 1ms
Bit rate mode : Constant
Bit rate : 12.8 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Stream size : 1.66 MiB (0%)
Title : SoundHandle
Writing library :
Language : English
mdhd_Duration : 1085640
