Am I on latest updates
Hi guys
I tried to update aircraft and camera via putting SD card in normal camera slot
It did not complete update as it should
Retried same constant red light and constant buzzing
I went back it Dji Go app and went to about
And I'd says
App version 2.4.2
Aircraft version 1.4.10
RC version 1.5.70
Am I sorted
Regards
Dermot
Dublin
Ireland
Nope. 1.5 is the latest firmware version for the Phantom. You can download it from the DJI downloads page.
The rc updated its the aircraft, camera and batteries that I think I may have a problem with
Try installing the firmware on your Phantom by following these instructions exactly. If the update fails, post the contents of the TXT file from your memory card here.
Hi
There was no flashing green/red when updating just a flashing red, and a solid red after about five minutes
it looks if I ha
here is the txt file
Delete history success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.08.16 17:42:07 =====================
Result: Abort.
Result: Abort.
========== 2015.08.17 21:03:44 =====================
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2015.08.17 21:07:13 =====================
Result: Abort.
========== 2015.08.17 21:24:28 =====================
Result: Abort.
========== 2015.08.22 13:08:25 =====================
Result: Abort.
========== 2015.08.22 13:13:02 =====================
Result: Abort.
Result: Abort.
========== 2015.08.22 14:23:04 =====================
Result: Abort.
Result: Abort.
========== 2015.08.29 14:03:01 =====================
Result: Abort.
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.09.07 19:14:36 =====================
Result: Abort.
========== 2015.09.07 19:16:03 =====================
Result: Abort.
========== 2015.09.07 19:16:52 =====================
Result: Abort.
========== 2015.09.07 19:32:11 =====================
Result: Abort.
========== 2015.09.07 19:35:41 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.09.19 16:34:41 =====================
Result: Abort.
Result: Abort.
========== 2015.11.30 16:43:40 =====================
Packet: P3X_FW_V01.05.0030.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Abort.
Upgrading ...
Result: Failed.
Your TXT file is pretty long. It appears to contain logs from previous installation attempts.
Are you sure you followed my instructions exactly? It looks like you at least skipped the step to format your memory card.
Hi
I did a full format
and tried to update again
I see the old dates that you refer to , but this is result from about 5 minutes ago
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Abort.
Upgrading ...
Result: Failed.
========== 2015.11.30 21:48:08 =====================
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
There is another hidden log file on your memory card. It's located at "MISC\LOG\P3X_FW_LOG_AB.txt". Please post that here too.
Hi
There is no hidden file or folder, as I formatted the card first,
I have seen a misc\log\ folder on another card that has videos and images on it
and other suggestions?
That hidden file should be there after you attempt to install the firmware update.
Did you try updating with a different card?
Hi
trying a different 32gb card and it seams to be working as I type, as it is flashing green and red which it was not doing on previous 2gb card
thanks for you help
Dermot
Good! It sounds like you might be all set now.
Hi
thanks for you help
Dermot
That's the funny thing about the P3. Certain micro SD cards just won't format via the camera/app or will be the cause of other issues like you experienced.
