Altitude
Hi. I've been flying my p3p every day now since I got it last week and I am noticing that the altitude is not very accurate. Is this normal? I take off and as I ascend it seems to be ok but I move down range, ascend and descend and when I bring the drone back and have it hovering in front of me about 10 feet high, my altitude is reading like 39 feet.
Now if I
Have it in my sight, I am visually flying not instrument flying, but I have been testing limits and if i fly it out 2000 feet or more at an altitude of 150 feet and then lower down to below 100 feet to "look" around and the drone is not in my field of view, a difference of 30 to 40 feet vertically could be disastrous.
Thoughts? Opinions? Advice?
Now if I
This doesn't seem unusual. When landing back at the home point I often get an altitude of 25-30 feet (when it should be zero). I believe this has been discussed in other threads and is caused by the temperature changes in the barometric pressure sensor over the course of the flight. If you are really concerned about it you can hover for a couple minutes to let things warm up and reach equilibrium, then land so it resets the altitude, then proceed with the flight. But there is still going to be drift in the altitude measurement over the course of the flight as the temperature will keep changing.
Reactions: andy238
Not sure about temperature changing. I live in Miami Florida and it is constantly hot. Today for example it is 82° and I'm in rural farmland ( Redlands). Flat as it comes.
If plus or minus 30 to 40 feet is the generally accepted altitude accuracy of the P3 then we all need to be sure to take this into account when setting RTH altitude. If you're thinking the highest trees are 60 feet and set your RTH at 100, you really should set for 140.
From a quick look at the specs of a typical barometric pressure sensor, temperature clearly has a big influence on the "raw" reading, but I think most of this include a temperature sensor to largely compensate for that effect. If anybody has identified the chip used by the P3 , it should be easy to find the expected temperature dependence. I think in some forum someone said it was 1 cm/sec for the P3.
Even if the sensor has zero drift itself, atmospheric pressure is always changing and this could also contribute to the error. The bottom line is that longer your bird has been flying, the greater the altitude safety margin you should allow.
I agree Fat City. And my concern was is this normal? Apparently it is so I will compensate and be cautious accordingly.
I am mastering looking down while descending then leveling out my gimbal on the horizontal, doing a 360° and seeing where I am height wise in relation to nearby objects. And I am going to take this margin of error into account for fail safe return.
I know this type of flying is unorthodox for photography, true but it is not just a platform for a camera, this this is fun as **** to fly. I have a boat, a Harley and this beats them all to hell right now in fun factor. Loving my P3P
Definitely give your self a nice margin on RTH altitude - it is extremely hard to judge the height of a tree from the ground. Best way is to fly to the vicinity and look at your altitude and give yourself a comfortable margin while realizing that DJI secretly believes in the concept of a flat earth. It is absolute altitude from your starting point, not relative altitude over terrain.
The aircraft people euphemistically refer to this as 'controlled descent into ground' - you don't want to to that.
The ONLY accurate measure of height would be a radar or laser altimeter. GPS isn't very accurate for height and a barometric altimeter needs constant recalibration due to changing weather.
I a hoping they will soon start using some sort of radar altimeter - we could have ground following capability then!
Interesting posts regarding usage of the barometer sensor (only) for P3 height measurement. Why wouldn't GPS/Glonass be used in GPS-P mode ?
As Wibble said above ..GPS isn't very accurate for height.
He's correct but GPS accuracy for altitude is much worse than not very accurate.
Despite giving pretty good accuracy in the horizontal plane - it's woefully inaccurate for altitude with errors of 100-200 ft commonly observed.
Hmm I am wondering how big this radar module will be and how much battery juice is it going to suck when in usage?
Personally I have noticed a few feet change in altitude in my P3A and I am suspecting it is quite normal. 25-30 feet change will be a bit too much for my comfort.
It need be no bigger than the ultrasonic module already attached. I don't know why they don't use that for altitude reading it works in a similar way but range would be very restricted.
I think it depends how it is used. With 15+ sats, there has to be a good least squares 3D centroid where the Phantom resides. The processing capability to correlate the position might be lacking, I would think that is a possibility. There are a lot of methods to calculate and improve the accuracy. Laser range finding might be used to get better elevation instead of a barometer. Modern manned commercial aircraft use ADS-B, based on GPS. So do JDAM smart bombs and Tomahawk missiles. Those are very accurate in X, Y, and Z 3D coordinates and based upon GPS.
wkflysaphan4
