pault said:
Mossie said:
Yes mine always reads about 11 ft when on the ground.
Similar here, usually always between 10 & 15'. Shame it does not set to zero on power up. It is intriguing to know how it calculates the height. It is obviously relative to your position and not ASL.
The control system has a barometric altimeter, which by definition measures air pressure. When the craft starts up, it presumably measures the current value and calls that "0", but there's enough slop so that it won't hold that value for long (thus the 10' or whatever).
Measuring absolute altitude requires barometric compensation--that's why airports always give an altimeter setting (the effective air pressure at sea level; you dial that into your altimeter to make it read *reasonably* accurately).
GPS altimetry is much worse; not only is the geometry of the satellites poor (the ones you really want to receive are blocked by the earth), but the altitude is relative to a model of the earth's shape that is only approximate.
In aviation, things like the minimum altitudes for instrument approaches have enough extra slop built into them so that errors of up to 100' or so won't kill you. I have three altimeters in my plane, and they match to only 50' or so.
The altitude reading should be placarded "for entertainment purposes only".
