Standard Altimeter
Discussion in 'Phantom 3 Help' started by drone2016, Mar 27, 2016.
  1. drone2016
    Hi
    My p3s shows often a wrong altitude . Usually display 10 15 mt less than real
    Is any calibration I can perform ?
  2. With The Birds
    Australia
    No.... you need to allow for the error unfortunately, it is a common and well known issue.
    It seems most apparent at the end of a flight from a cold start. In my experience i had a greater error when running with a cold imu calibration (placing the phantom in the fridge immediately before calibrating). It seemed that recalibrating closer to average flying temps went a long way to resolving the issue.
    If i am flying where altitude is likley to be critical i do it after flying a full battery first and find less error.
  3. Meta4
    Meta4 Moderator
    Staff Member
    The altimeter is part of the IMU.
    Try recalibrating the IMU on a perfectly level surface.
    That might fix your problem.
Similar Threads - Altimeter Forum Date
P4 with latest firmware: spontaneous altitude change and poor altimeter precision after upgrade Phantom 4 Discussion Jul 29, 2016
Altimeter off 50' at times Phantom 4 Discussion Jul 25, 2016
Terrain Radar Altimeter App - FREE Today General Discussion Jul 4, 2016
P3 Pro altimeter vs sonar reading off by 30FT Pro/Adv Discussion Apr 5, 2016
Altimeter for your bird Off Topic Feb 27, 2016
