After the crash??
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by tymb, Aug 26, 2014.
  1. tymb
    For whatever reason the Phantom 2 just stopped responding to the controller. Just beginning to start to figure out what that was all about. The Phantom looks to be ok (outwardly at least) but the H3-3D gimbal was damaged. Hopefully it can be rescued. I need to straighten out one of the metal mounting arms but I can't figure out how to remove the washer that holds the plastic pins in place. Looks like the only option would be to cut the pin as I can't pry it off?
  2. freefall101
    I asked the same thing here viewtopic.php?f=26&t=24026
    It looks like cutting them is the only option, they appear to be one use only and not reusable, hence the extra pair which come with the Zenmuse H33D.
    As for the crash, did failsafe (return to home) not kick in?
  3. tymb
    Ah, so I'm not the only one. :) Thanks for the input. I guess it wouldn't hurt to order some extras while I'm at it.
    Fairly new to the Phantom 2 but have flown enough to become quite comfortable with it-- even around some obstacles given there's not a lot of wide open space around the house. I was in the process of landing, it was only maybe 20 feet up and for whatever reason it just decided to drift away toward a nearby tree. Clipped a few branches and fell to the ground.
    I also would like to see someone answer the question you asked in the previous post you made:
  4. OI Photography
    Clarksville, TN
    [​IMG]
    [​IMG]
    Just tight enough to not flop around, but not tight enough to compress the dampener.
  5. tymb
    What took you so long? :mrgreen:
    Thanks much for the quick response. I may have to try this method myself.
  6. OI Photography
    Clarksville, TN
    Sorry, had to get the studio set up just right ;)
    I actually took those a few days ago for just such an occasion. They're a cheap simple solution, and you know the odds are that the one time you don't use something like that is the one time you land a little hard and the gimbal comes flying off the dampeners :roll:
  7. freefall101
    Thanks OI, so basically you don't use those plastic securing pins and instead simply loop around one plastic cable tie in each of the two corners? Good idea....
    Edit: also, what is the white plastic around your GoPro and gimbal, some sort of anchor to hold it in place?
  8. OI Photography
    Clarksville, TN
    You got it! I'm certainly not the only or even first person to think of that, it's just what I've been doing since I first got my gimbal.
  9. tymb
    The Vision + I had previously (had to RMA) has that kind stabilizer. Really miss that w/ the 2. You made this yourself?
  10. OI Photography
    Clarksville, TN
    If you're talking about the white retaining bracket that holds the camera in place, I got it here: http://www.raveaerialvideo.com/product/ ... l-bracket/
    Not sure where you are, there's also a dealer in the US that carries those but they're out of stock at the moment.
  11. tymb
    Thanks for the details. I'm in the US but will look around and see if I can find one in stock somewhere. Would be good to stabilize the camera and keep it from flopping around.
Similar Threads - crash Forum Date
Motor overload warning --- impending crash ?? Pro/Adv Discussion Yesterday at 3:50 PM
Crashed my phantom4 for unknown reason Phantom 4 Pro Help Monday at 2:31 PM
Litchi crashing? Standard/4k Discussion Sunday at 4:35 PM
Drone pilot could face charges in connection with deadly crash News Saturday at 10:38 AM
I see so many guys posting and asking why their Phantom crashed General Discussion Aug 17, 2017
