After replacing front left ESC this happens...
Discussion in 'Phantom 2 Vision + Discussion' started by Jenko1989, Dec 19, 2014.
  1. Jenko1989
  2. dutch
    Upstate NY
    is your remote on when you start it up?
  3. Jenko1989
    it wasn't this time, but it does it even when the remote is on. Why do you ask?
  4. probonic
    Manchester, UK
    If I'm not mistaken, different versions of the ESCs do different number of beeps at startup.
  5. dutch
    Upstate NY
    I had the 4 beeps at one time while turning on the phantom and not having the remote on,
    so after that i turn the remote on first and haven't had it beep like that.
    but, i'm very new at this, and it was a hunch
  6. ilovecoffee
    That's normal.
    That's what happens on the Phantom Vision 2 (non plus) to indicate everything is OK with the ESC. The ESCs are the same between these two Phantoms, except for the beep.
    I've replaced mine as well so now I also get the four beeps from that ESC. Each ESC will beep independently. So if you don't get 4 beeps, something is not right.
  7. Jenko1989
    Ok, because it didn't do this before I replaced it. So for example if I replaced all 4 Esc's then would they all beep 4 times and light up red like that?
  8. CityZen
    NYC
    It's due to the different (firmware) versions of the ESC. Older ones have extra 4 beeps; newer ones don't. The lighting is also different.
  9. RoyVa
    Virginia
    You will probably find that that ESC you just replaced on the white sticker it is a version 2.1 and on your other ESC they are version 2.0 . Completely acceptable. The 2.1 is just a newer firmware. Will work fine mixed. That is probably the reason you are seeing a difference. As long as your motors start and stop at the same time from idle and full throttle you should be in good shap to fly.
  10. hunch
    above comments are correct. different fw esc's in the same bird will do that, however test one thing right away, get the video
    on your mobile device and turn on the motors.
    do you loose video or is it still there? it happens on occasion because of different fw escs
Similar Threads - replacing front left Forum Date
How do you know what needs replacing after a crash Canada Jan 9, 2018
Standard what else can i do rather than replacing Phantom 3 Help Nov 17, 2017
Replacing P4 Gimbal/Camera Unit Phantom 4 Discussion Oct 6, 2017
Replacing adhesive on flex ribbon Pro/Adv Discussion Sep 20, 2017
Professional How to initiate the "Aircraft Initiation" after replacing pn #96 ESC board Phantom 3 Help Aug 4, 2017
