After flying my p3a. It got to about100 ft and then returned to home. It was showing disconnected.
Mandurah. West aust
After checking i found that the cable in side the rc coming off the antenna brass screw had broken off the connection, i re soldered the cable back on and checked the connection and it appeared ok. A multi meter showed continuity. Any ideas why it still shows disconnected
And wont start.
And wont start.
Try re-linking the RC and quad.
Anytime P3 loses connection beyond 100 yards, it's a clear indication of disconnected/ ineffective antenna. It could be on RC or on AC.
Thanks for the advise as i stated the antenna. Cable was broken from the brass screw inside the rc. So i think i will purchase another cable and see if that solves the problem. Once again thanks for your info
Also it is advisable not to fly with broken antenna as it might toast the tx circuits.
Alokbhargava is 100% right so hopefully the tx circuit is still ok, it's not even advisable to turn the rc on with no antennas.
Also do not buy a cheap replacement cable from China, they are crap and break easily, Been there done that.
mactechnic
