I just could not believe....
@Hoppinrocks you have almost exactly the same problem as me. I think we can help each other
My story:
I was flying my P3ADV v2 on Litchi app with autopilot. Part of the route was planned beyond of the transmitter range. I knew that I lost control for 45 seconds until the craft returned from the loop. The furthest point was 3.7 km from the RC. I have been flying this path many times and I knew that perfectly. That is why I allowed myself to modify the path live with the sticks during the execution. That day weather was very strange. Did I mention that in the midst of the distance between the RC transmitter and the craft there is a high voltage line? 110 kV at an altitude of 125m ?
I pulled up long long before the critical point but this time I lost the signal earlier than ever. The autopilot tried to pull up but suddenly the birch-tree grew right out of the path.
ok, I overdid the length of the description. Let's go back to the case. Here is my only damage:
Missing elements could be capacitor or resistor even coil. I am a programmer not an electronics engineer, but simple soldering and electronics repairs have always attracted me very much. I wrote long inspirational letter to DJI support asking them for help:
Dear DJI team. Please help me determine what elements should be in places #A and #B (marked in the photo). I have the right soldering equipment and skills.... ...For you it is a matter of looking at the matherboard scheme..."
The response was (as you probably expect):
With regards on your inquiry... bla, bla, bla... we do apologize but ...bla, bla. ...DJI Technical Support cannot mess with motherboard... haha bla, bla, ...repair is not as easy as you think... "
Stupid ignorants! Talking to them is a waste of time...
First I noticed that the missing SMD elements are from one of engine controllers. There are four on each mainboard. So using motor M3 controller I can see what is missing on
M2:
I spent tons of time looking for pictures, diagrams, tips in different threads on different forums, comparing photos etc.... I was close to give up and order broken ESC mainboard (DJI part 96) to transplant the missing SMD elements.
Then I found great github repository by
mefistotelis.
It is awesome, see it:
P3X ESC center board · mefistotelis/phantom-firmware-tools Wiki · GitHub
I found what I was looking for:
I discovered that my missing SMD elemets are 100nF capacitors. It is very useful because it is not possible to mesure capacity without unslodering the element. In oposite to capacity we can measure the voltage on board. It is 63,2 mV:
I ordered new capacitors 100nF 62mV as it is very common SMD part. Unfortunately it occured that the size of spare part is 3 times bigger than I expected:
I stopped on this. I know that very small SMD elements have no inscription. To find the element details or name you have to measure it and look to the SMD elements catalog to find the right one using L x W x T.
Probably (I'm guessing) need a capacitor with the same parameters but in another different housing?
I tried to measure small capacitors without unslodering it from the mainboard. It is very difficult
I think it is 1,08mm (L) x 0,5mm (W) I dont know how tall it is. It seems to be 0,4mm (T) but I did not measured it, so it is my guess as well.
Any hints and tips are very welcome
