Adding iOSDmini to existing hex build
Oklahoma City, Oklahoma
I'm stumped...just finished a new F550 with Naza M V2, PMU and GPS. Everything works great-no issues. I'm adding FPV to this hex and plan to use a Fatshark video tx (left over from another quad that's idle), iOSDmini and Lumenier CS-600 camera. Also plan to go to a 4S on this hex for better flight times.
I know there will be a issue getting proper voltage to the camera (per Lumenier's specs the camera will take anywhere between 9-12 volts), which means I'll have to drop it somehow, but that's not the issue I'm dealing with right now.
My immediate problem is I can't figure out where the iOSDmini hooks up in this arrangement. On my P2, I plugged in the iOSDmini directly into the "CANBUS" connector which is conveniently mounted on the landing leg of the P2. But I don't have one on the hex. Do I need to buy the CAN HUB to make this work?
Thanks!
Fred in OKC
Do you have the little black box that's labeled Naza PMU V2? That should have a CANbus on the side.
wkflysaphan4
