Adding a GoPro 4
Barnesville, PA
I have a H3-2D Zenmuse that I want to use the Hero4 Black With.
If I do the H3-3D cable mod and plug into the side of the HEro4, Will my ISOD Mini still work?
The way you asked the question I'm going to assume that you are using DJI hud. Is that correct? Why not list your equipment.
The Hero 4 Black will only work with the ribbon cable no matter which Gimbal you're using.
Fdnyfish said:
I did list that I have a Dji iosd. Can you please explain what a DJI HUd is?
Misspelling DJI HUB is a plug n play module that uses the gimbal cable coming from inside the P2 to feed power to the TX, iOSD and the gimbal. The reason you cannot plug the hero 4 into the 30 pin connector on the H3-2D gimbal is the Go Pro changed pin connections on the camera so on that gimbal the 30 pin connector has to be removed and replaced with the ribbon cable. There are YouTube videos on the subject research them.
jrl
