job2310 said:
I think the answer depends on the wifi channel each is using. It's no different than you and your neighbour both having 2.4Ghz routers in your house. If they're on the same channel both of you will most likely experience negative wifi reception. If they're fairly well separated then there is less of a chance of problems.
This would be incorrect. When it comes to Wi-Fi, it is better to be on the same channel than a neighboring one. Keep in mind, there is only room for 3 non-overlapping Wi-Fi channels in the 2.4GHz ISM band. And the P2 doesn't use Wi-Fi or abide by it's rules. Fortunately, the P2 uses a protocol designed to work in a crowded ISM band so it can share the same space with Wi-Fi as would be the case between a P2 and P2V.
A P2 should have no issue working with a P2V in operation nearby.
