A Couple Of Questions That Have Probably Been Asked Before
Discussion in 'Pro/Adv Discussion' started by Fnichols1, Jun 21, 2016.
  1. Fnichols1
    My P3A has around 800k ft on it, with no problems except for the occasion signal issue. Recently, I have noticed three things:
    1) When flying in a straight line, without touching the left stick, it seems to turn slightly right. It is not drifting and is always in P-GPS. It just turns a little, requiring I make an adjustment. I have to be moving, though. When I stop and hover, it always locks in position. Any thoughts to that?
    2) The rear motors are slightly warmer to the touch that the front motors after a long flight (20k+). I ALWAYS flight forward, so I am assuming it is because they are doing more work. Would that be accurate?
    3) The right rear motor is slightly warmer to the touch than the left rear motor. Again, it is SLIGHT. The motors are never too hot to touch and hold. It is just a minor (perceived?) temp difference. Should I be concerned?
    For background, after each flying session, I pull the props. I verify the motors spin up at the same time, and I listen for any strange noises. There are none. I also hand turn the motors regularly to feel for binding. I have not felt any.
    Probably paranoia on my part, but most people here have a lot more experience than I, and I appreciate the input and advice.
  2. RedHotPoker
    Edmonton Alberta
    If your drone is veering to the side slightly in travel, perhaps you only need to recalibrate the IMU and Compass.
    Not sure about warmer motors, but if you want to know actual temperature numbers, buy an RC laser thermometer. Heat gauge will tell you exactly.
    How is everything else working? Camera ok? ;-)
    RedHotPoker
  3. Fnichols1
    Thanks for responding. "Veering" may be the best way to describe it. It is not a constant veer and is slight enough that I thought it was the wind initially. I guess that possibility is still there. Everything else is perfect. Camera is steady, video good, the horizon is level. I did an 18k flight out and back, stock, with no signal issues. Even after that, the motors were only warm, not hot.
  4. hunch
    calibrate sticks also in the app when phantom is off.
    Reed L likes this.
  5. Reed L
    Alta, Ca.
    +1 - hunch knows. It definitely sounds like a minor stick calibration problem with the rc.
  6. RedHotPoker
    Edmonton Alberta
    Sure, Sticks should be done too, removing all obvious variables.
    Hopefully you get this corrected, however minor the deviation. ;-)
    I have gotta' admit, how much I love the fact, that my drone flies exactly where I aim and direct it.
    Object avoidance would certainly benefit this too. Hahaha
    RedHotPoker
  7. Fnichols1
    Hunch, thanks. Reed, thanks for the link. That makes sense on the veering. I will do that tonight and test it in the morning.
    RedHotPoker, I appreciate the suggestion. I calibrated the compass at the flying site, but still had the veering. I will recalibrate the IMU after I work up the courage to install the latest firmware update.
    hunch likes this.
  8. RedHotPoker
    Edmonton Alberta
    Eh, the latest firmware is Rock-solid, so fear~not. Haha
    I can only voice personal opinion and experience, but if you have a trouble free drone, this update won't hurt you. ;-)
    Now some folks are saying recalibration of the IMU isn't critical after any of these firmware updates. Go figure. Each to their own. YMMV but I prefer to err on the side of caution. Besides I enjoy the chilling procedure. Haha
    RedHotPoker
Similar Threads - Couple Questions Probably Forum Date
Couple of probably obvious questions :) Phantom 2 Vision + Discussion Sep 22, 2014
Couple of connection questions Pro/Adv Discussion Oct 7, 2017
Tried to fly today for the first time. Got a couple questions..... Pro/Adv Discussion Aug 30, 2017
Considering an Advanced. A couple of quick questions Pro/Adv Discussion Jul 28, 2017
Standard Getting ready to do the Inspire 1 tablet holder mod. A couple of questions. Phantom 3 Help Jul 24, 2017
