Help plz.
I had an unfortunate mishap with my P4 causing one of the arms to be completely broke.
I replaced the shell and a 2 of the engines.
I am currently getting the error "3no.ESC Error".
I've read several comments that it could be due to weak solder connections. So, I am thinking of un-soldering all the engines, cleaning the wires and re-soldering them. The soldering iron I was originally using was a poor choice for the job and I suspect I might've done some heat damage to one of the ESC boards, but I am unsure.
1) Is the 3no.ESC Error likely a wire/solder issue?
2) Is there any testing that I can do to help me dissect the issue (testing the ESC board)?
3) Where might I find some technical information that could help me determine the issue?
4) Ideas/suggestions?
Any help is appreciated. I will post my results if/when I get this resolved.
Thank you.
Thank you.
