3D print gimbal
This is what it looks like when made.
I have tested it, and it kinda shaky. Think i need to add more support to the main mount.
You could take the original gopro mount off, and use the brass inserts in the Phantom instead.
It would make better contact with the body,(less room for harmonics) make the mount further forward( to avoid those arm and leg shots), and you could add moon gel if you wanted to keep the jello to a minimum.
After a bit of testing, it seems like it's too flexible and causes to much vibration than stabilization.
I have now ordered new carbon fiber props, brushless gimbal motors, rubber dampeners and Alexmos card.
Will try to design a new model to be printed or use the Skylight design...
